- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Overlay .dwg file
Hi All - Im trying to overlay a .dwg file from and engineer and Im having trouble. (auto cad LT for MAC)
I go to INSERT and select OVERLAY and select the file.
It then takes me to the model screen and asks me to insert an insertion point? How do I know where this is?
Sorry for the silly question - I haven't done this before.
I have created a landscape plan on top of the civil drawings initially provided to me - They have updated these civil drawings and I need to check the changes in the road design.
Thanks so much!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The insertion point can be located anywhere - at your request.
Another thing - if you need to align two drawings (engineer and yours) - than you can insert external reference at any point and than manually align it with your drawing contents using known reference points.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
To add to this thread you can look to the following videos and help link.
Change Overlay/Attach Setting for XREF
Overlaying Viewports in AutoCAD VAR2015
Help file:
If you'd like you can add your drawing files here and I can run through the steps as well on my Mac. Post back if you need additional help.
Sarah Emmsley
Technical Support Specialist
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
THANKS SO MUCH!
I have attached the two plans - my plan is the Landscape Plan August.
Cheers Nadia
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Ok I'll take a look at what you got and get back to you. Also let me know if those videos helped with your workflow.
Thanks.
Sarah Emmsley
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Emmsleys,
Thank you so much!
Unfortunately - they didn't - The first video I couldn't quite follow.
Im having trouble with getting the drawing to show up when i go to insert the insertion point/scale.
I would be so grateful if you could have a look - thanks!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
At first you need to set coordinate system in both drawings (master and external reference) to World coordinate system (WCS).
In master drawing turn on current layer (I noticed that it is turned off).
Than in your master drawing, use menu Insert -> DWG reference, select external reference, select options in Insert DWG window, select OK and when AutoCAD will ask for the insertion point - type 0,0 and hit Return.
Reference should be in correct place.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Here is your master drawing with reference attached in correct place.
Maxim
Maxim Kanaev
Architect
MARSS
