08-15-2016
05:18 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-15-2016
05:18 PM
If I have a layout with multiple viewports, I cannot consistently freeze a layer in one viewport and not the others. It may work one time, but upon switching back and forth from model space to paper space, the layers don't stay frozen. I am trying this with dimension layers.
¡Resuelto! Ir a solución.
08-16-2016
01:46 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
08-16-2016
01:46 AM
Have you tried to use LAYFRZ command?
Activate viewport, click on Freeze Layer button on the Layers palette, than verify settings, they should be set to Vpfreeze:
Command: _LAYFRZ Current settings: Viewports=Off, Block nesting level=None Select an object on the layer to be frozen or [Settings/Undo]Settings Enter setting type for [Viewports/Block selection]Viewports In paper space viewport use [Freeze/Vpfreeze] <Freeze>: Vpfreeze Select an object on the layer to be frozen or [Settings/Undo] <- select object on the Layer you want to freeze here Layer "XXXXX" has been frozen in this viewport. Select an object on the layer to be frozen or [Settings/Undo] Command:
Maxim
Maxim Kanaev
Architect
MARSS
08-16-2016
03:57 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
08-16-2016
03:57 AM
I usually use the buttons in the layer manager to control the options. I
will try the LAYFRZ command to see if I have different results.
Thank you.
Thank you.
08-17-2016
02:56 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
