715 Vistas, 14 Respuestas
Autocad 2016 Mac, will not respond after extended idle time.
Mac Autocad 2016, fully updated.
Fresh start-up of the mac and Autocad will open and run fine.
I usually leave my mac on overnight with autocad running.  My mac sleeps after a given time.
Return the next day and autocad is unresponsive.  Autocad shows as running in the doc but will not appear on the screen.
If I quit Autocad, let the mac sleep overnight, then return the next day....  Autocad will not start but will show the little dot under the program in the doc.
If I force quit autocad it will not start again.
This happens 75% of the time I leave my mac on overnight.
I have to shut down my mac each day in order to rely on autocad opening when I need it to work the next day.
This only happens with autocad, no other programs.
Thanks in advance! :cara_con_una_leve_sonrisa:
