Azmeera.M
en respuesta a: Azmeera.M
ARCHIVE
January 2016
Properties Palette - ‘ByLayer’ Linetype Preview Doesn’t Refresh in AutoCAD for Mac
February 2016
How to use annotative text and dimensions in AutoCAD
March 2016
AutoCAD for Mac 2016 enable right click as secondary not working with move command
How to create Multilinestyle in AutoCAD for Mac
How to reduce PDF file size when exported from AutoCAD for Mac
Missing objects in a PDF created in AutoCAD for Mac
Trouble attaching xref drawings in AutoCAD for Mac
April 2016
“Display Locked” for Polygonal or Object Viewport in AutoCAD for Mac
Unable to calibrate plotter with AutoCAD for Mac
Clicking ENTER on context menu (right-click) after entering dimension not working
Color palette 89 and 109 is not the same as shown in preview
Crosshair is difficult to see in block editor in AutoCAD for Mac
Dimension text plots larger than expected in AutoCAD for Mac
Files become locked and performance is slow in AutoCAD for Mac
Generating a Mac OS Sample file
How to add custom field to a project in AutoCAD for Mac
Lag when using certain commands in AutoCAD for Mac
May 2016
How to assign materials by layer in AutoCAD for Mac
June 2016
How to generate a DWF from AutoCAD for Mac
How to view DWF files on the Mac OS without AutoCAD
AutoCAD for Mac window is larger than screen and cannot be resized
Where are the CUI files located in AutoCAD for Mac?
July 2016
AutoCAD LT for Mac: Trim/Extend Multiple Elements in Revit cuts some lines incorrectly
Cannot embed or display OLE objects in AutoCAD for Mac
Drawing Recovery shows file is in use or read-only in AutoCAD for Mac
Shockwave Player Error causes AutoCAD for Mac to hang on launch
Text missing in printed results after installing AutoCAD for Mac Update 1
Unable to find the ribbon in AutoCAD for Mac
August 2016
AutoCAD for Mac writes backup and autosave files to the Documents folder
Cannot turn off Autostacking of fractions using dialog box
DGNIMPORT does not work in AutoCAD for Mac
How to share drawings with attachments with others using AutoCAD for MAC
September 2016
AutoCAD for Mac runs slow and freezes
AutoCAD LT for Mac: Purge Dialog window does not appear when executing the command
Differences between AutoCAD and AutoCAD LT for importing 3rd-party data
Plot style tables in AutoCAD for Mac shows up empty
Plotting in ACAD LT for Mac outputs color whatever the Plot Style Table used
Poor graphics performance with AutoCAD for Mac products
Problem copying ctb files within MAC
Saving DWG is very slow in AutoCAD for Mac
Uniform Layout Background in AutoCAD LT 2016 for Mac
Which versions of AutoCAD are available for Windows and the Mac?
Azmeera M.
Autodesk Employee
