07-15-2016
10:46 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-15-2016
10:46 AM
HI @Anonymous,
This kind of functionality is where AutoCAD Map is really great. In regular AutoCAD, database connectivity is possible. Here is a link to a Tutorial on some of the functionality possible. This example uses Access but if you can create an ODBC connection then your database should work although I have tried Access myself.
Perhaps to get to your Circle zoom you can view the linked item as demonstrated. I hope this helps to get you started.
[EDIT}
I just realized this is AutoCAD for Mac. This functionality is not available on the Mac Platform. If running Windows-based AutoCAD in Bootcamp this should work fine though.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
