07-11-2016
11:20 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-11-2016
11:20 AM
Welcome to Autodesk Forums!
You can use different methods according to your needs:
- Use clipboard to copy entire drawing and paste it to another drawing - open two drawings, than use menu Edit -> Copy and select all objects in the drawing, than switch to another drawing and use menu Edit -> Paste.
- Use INSERT command (menu Insert -> Block..., than use Browse button to navigate to the drawing you want to insert into opened drawing) - you need to check "Explode block" if you want to insert drawing as individual objects.
- Use menu Insert -> DWG Reference to insert external DWG as reference - a kind of block, which you can see inside current drawing, but you need to edit it separately.
Maxim
Maxim Kanaev
Architect
MARSS
Maxim
Maxim Kanaev
Architect
MARSS
