- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
The drawing actually doesn't feel slow on my side even though for an AutoCAD file it is rather large at 5 MBs. I did notice however, that an Audit found 50 errors. Purge found 218 zero-length objects and 3 empty and -purge>regapps found 17 applications to delete.text objects.
You also have several floor plans and elevations all in one modelspace. You might consider separating things into separate drawings and xrefing into this one drawing. Also, you use quite a few layout tabs in your drawing. While this works, recovery later might be an issue if your drawing gets corrupted.
I see that you have grid turned on. I suggest turning that off unless you are actively using it.
Lastly, you have a bunch of xref missing many of which are raster images. This many raster images will also make things a bit slow.
I have attached the "cleaned up " drawing. Please let me know if it behaves any better for you.
John Vellek
