958 Vistas, 14 Respuestas
cadlt for mac freezes when saving/exporting a pdf i have to force close
Hi I have been trying everything to resolve this issue. I have a client urgently awaiting the pdf for planning and I have exhausted myself and every option I could think of! Basically as the title says cadlt for mac freezes when trying to save/export/preview as a pdf.
Any help would be greatly received
Danielle
Etiquetas (1)
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Daniel,
As possible quick solution I can suggest you to try to create new user account - just for test, you can later remove it.
Than login to this new account, launch AutoCAD and try to print top pdf from this new user account.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Hi thanks for the quick response! forgive me for being naive but how do I
do this?
Thank you Danielle
djogs Landscape Architect, 79 Green Lane, Pelsall, Walsall WS3 4PD
01922 442665 mob 07812640015 mob 07434 821716
www.djogs.co.uk
Landscape design and Ecology Services. Environmentally sensitive and green
belt projects a speciality
Landscape Institute member 23007
maxim_k
Please look here:
https://support.apple.com/kb/PH18891?locale=en_US
You need "Add a user" section - the type of user could be administrator or standard user.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Hi Thanks again for prompt response, I cant seem to add a user then log in
as the new user and access my cad programme? or any of my programs?
Sorry I do really appreciate your help
Danielle
www.djogs.co.uk
maxim_k
>>>I can't seem to add a user
Why?
It is so easy to open Users and Groups pane of the Mac OS System Preferences, than unlock "Padlock" with your password:
Than click on + button:
Than fill everything in this window and click on "Create user":
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Hi maxim, I have no problem creating a user, it's when I log into the new user cadlt isn't anywhere on the new users interface?
Danielle
Sent from my iPhone
maxim_k
It should be in the Autodesk folder inside Applications folder, which is acceptable from any account (except from Guest user account).
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
OK
Another way to try to resolve the issue with freezing when printing is to reset AutoCAD from Application tab of AutoCAD preferences.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
john.vellek
Hi @Anonymous, I know you are in excellent hands with Maxim_K.
Now that you have created the new user and logged on with that account, simply use the magnifying glass search tool at the top right of your screen. Type in AutoCAD and it should find the application for you.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
en respuesta a: john.vellek
Hello all
Thank you once again for all your help
I have had a reassuring email off Autodesk support after raising a case last week, so it seems my 16 hour days trying to resolve this issue and buying a brand new Mac havent been in vain I've learnt a lot from googling and landing in these forums thank you.  Apparently it is a problem with Cadlt for mac, its freezing when trying to plot one of the many hatched areas. They are going to log a bug report with their development team and send them my drawing to test. There are ways around this but it would be extensive so the the quickest solution is to save it on a windows version of mac to print/save as Pdf, Lucky I still have my old mac with parallels.
Danielle
Etiquetas (1)
wei503
Hi @Anonymous,
Could you please send me the drawing which can reproduce the issue, and let me know which area/layout did you print? I assume your OS version is 10.11.5 El Capitan. I'd like to push on a fix for this issue, and being able to reproduce it in our development environment would be very helpful.
You can reach me at: wei.ma@autodesk.com.
Wei
Wei Ma
AutoCAD QA Manager
en respuesta a: wei503
Thank you!
Danielle
maxim_k
Hi Danielle,
I'm just curious which specific hatch pattern force AutoCAD to hang during printing (exporting to PDF)?
Can you also attach one of your problem drawings here?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Hi Maxim
Of course please find the attached Dwg
Its the gradient hatches that are causing it to lock. I would appreciate
any help with this as the clients still having problems her end
Regards
Danielle
www.djogs.co.uk
