706 Vistas, 9 Respuestas
programm chrashes when editing dimension style
I´m having some problems with my Educational version of AutoCAD 2013, whenever I want
to change the dimension style in dimension style manager the program
shuts down. I´ve read on other forums that it might be a compatlility
problem with mac, my version is 10.10.5 OS X Yosemite. I´ve tried
to download service pack 1,2 & 3 and none of them want to download on
my computer and I don't know what else to try.
Do you know what I can do regarding this situation?
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Does this happens in all of your drawings?
If yes, and you are sure you have OS X Yosemite, than try to reset AutoCAD from Application tab of the AutoCAD preferences.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Hi thanks for the reply. I tried to reset the applicaiton options in preferences nothing changed and the program still crashes. There's also an update due on my autoCad but I can't finish the download an error comes up that my computer has to be 10.6.4 or later as my computer is. I attached a picture, that problem came also when I tried to download the service packs.
maxim_k
Can you try this:
-remove AutoCAD with Remove AutoCAD application
- download full installer which includes all Service Packs from here:
https://knowledge.autodesk.com/support/autocad-for-mac/downloads/caas/downloads/content/autocad-2013...
And install AutoCAD again.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
Hi @Anonymous,
Were you able to try the suggestions made by Maxim? Did they help resolve the problem?
Post back should you have any other questions.
Sarah Emmsley
Technical Support Specialist
Hi thank you. I've been trying to uninstall it that way and it doesnt seem to be able to do that from there, is there another way to uninstall the program? I attached at the place of the uninstallment process it stoppes.
Emmsleys
Hi @Anonymous,
I would try manually uninstalling AutoCAD 2013. It was a known issue with Yosemite and El Capitan.
I have provided the article to help guide you along if need be: Clean Uninstall of AutoCAD for Mac
There is also another forum thread that Maxim posted a solution mentioning this specific topic here
Sarah Emmsley
Emmsleys
HI @Anonymous,
Following up on this thread, I haven't heard back if you were able to try the suggested steps.
Please post back in the thread if you are still having an issue with AutoCAD the community and myself will be more than happy to help.
Sarah Emmsley
en respuesta a: Emmsleys
Hi Thank you for the help. It worked out to reinstall the program.
Cheers.
Emmsleys
Hi @Anonymous,
Thank you for posting back in the thread with an update.
Have a good week. Emoticono feliz
Sarah Emmsley
