maxim_k
en respuesta a: Anonymous
Hi A,
After you convert polyface meshes to Mesh objects with MESHSMOOTH command you need to set Smoothness level of the resulting Meshes to "None" via Properties palette.
Look at the attached DWG, where I converted all pface meshes to Meshes with smoothness = None.
You can also find FLATSHOT result in the attached drawing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
