john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
This is actually pretty easy to do on a one by one basis.
Open the Hatch Library on your screen in AutoCAD for Mac.
Drop down the list to show Custom
Towards the bottom of the list is "Add Patterns"
Select this and it allows you to add the hatch pattern.
If you want to get into the Hatch location on your Mac, the default location is /Users/<username>/Library/Application Support/Autodesk/AutoCAD 2016/R20.1/roaming/@en@/support/Hatch Patterns.
Normally this location is hidden. So, in FINDER select HOME from the GO menu. Next, from the VIEW menu select SHOW VIEW OPTIONS. near the bottom selet SHOW LIBRARY FOLDER
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
