- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
hi Everyone
when i making polyline object
i pick every corner point and i connect tow or three lines ofter that it is disappearing showing polar traking cursor
then i cannot finish the object.
when i making rectangle
i pick one corner the i go to another corner accidently i move my cursor to corner of some object my cursor automatically take the snap
then i cannot finish my rectangle
sometime i pick both corners but i cannot see the object then i can see in print preview only i also showing cross lines
if anybody know please help me
thank you.....
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If you cannot see what you draw - please verify that active layer is turned ON.
You also may need to turn off running object snaps with F3 (or Fn+F3) keyboard key.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi msdurai,
If OSNAP or Object Snap Tracking is getting in your way, you can use the F3 key to toggle OSNAPS on and off. You also rt-click on the OSNAP settings button on the bottom of your screen of you can find it also in Drafting Settings (DSETTINGS).
Ortho mode is toggled by F8 and Polar mode is toggled by F10.
If you need to access Object Snaps while in a command, try Shift-RightClick .
I hope this helps.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi msdurai,
I am checking back to see if my post or @maxim_k's helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous, I'm glad that you find the Community Forums helpful. You might want to check out the other resources available for learning too. (Link Here to Prior Post regarding training)
John Vellek
