2232 Vistas, 3 Respuestas
Insulation Hatch in AutoCAD for Mac
Hello people, I am am Mac user and I am trying to use the insulation hatch but I can't make it fit the shape that I want. Is there a command that I can use to make it fit?
Thank you in advance
@Anonymous,
john.vellek has edited your subject line for clarity:how to fit insulation hatch into a shape
Michiel.Valcke
en respuesta a: Anonymous
Make sure you use a closed polyline to select as a hatch boundary. If the polyline is open hatching will fail. You can check whether a PLine is open or closed in the properties.
If you have trouble closing your polyline you can also use the _.BO or _.BPOLY command to create a closed polyline for you.
john.vellek
Hi xouzouriniii,
As @Michiel.Valcke mentions, a closed area is required to get any hatch to work. BO (boundary is a great way to get this to work if your lines are really close but not quite closed.
I have attached a Screencast for you that shows a batt insulation I downloaded and then add to my hatch library. I insert this into a wall that is closed on the ends. WHen I do this I see that the hatch needs to be rotated 90 degrees and then I scaled it up as well (x16). Lastly, I change the origin point for the hatch so it looks centered in the cavity.
I will attach this pattern to this post as well.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
Hi xouzouriniii
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
John Vellek
