838 Vistas, 12 Respuestas
page setup dialog box goes missing in 2013 - El Capitan
When trying to print from either paper or model space the page-set up dialog box that allows to choose plotstyles etc goes missing. Very irritating as I can't print anything to the plotter or to a PDF with the correct print settings anymore. Crazy position to be in for a drawing office...
Im running AutoCAD 2013 on MacOS 10.11.3 (El Capitan).
Is there a patch available?
Many thanks
Erfan.
rkmcswain
en respuesta a: Anonymous
Is the dialog just off the screen?
TheCADnoob
as @rkmcswain mentioned i would look to see if it is off screen.
Hit:  alt+spacebar and then hit M
This should give you keyboard control over your dialog if it is off screen. So then just simply use the directional arrows to move your window on screen.
CADnoob
en respuesta a: rkmcswain
kind of, attached is the screenshot:
get an error sound if i try to click outside of the box - can only esc out.
rkmcswain
en respuesta a: TheCADnoob
Do Macs have an ALT key?
Yes, that solution doesn't do anything I'm afraid.
Sent from my iPhone
TheCADnoob
From your screen shot it looks like you are running OS
edit: and as @rkmcswain pointed out id didnt catch the mac thing even though it was in front of my face sorry :cara_con_una_leve_sonrisa:
Check to see if some of the suggestions in this post help
http://forums.autodesk.com/t5/autocad-for-mac-general/disappeared-quot-edit-page-setup-quot-dialogue...
CADnoob
TheCADnoob
I have a problem with reading lol sorry.
CADnoob
Yes, I'm running El capitan (10.11.3)... Which AutoCAD 2013 seems to have some issues with.
Will read the thread and see if there are any relevant solutions on offer
Will post again and let you Know
Sent from my iPhone
pendean
Read the bad news here http://autode.sk/1L7mTXs
Tim to upgrade your AutoCAD for MAC version.
rkmcswain
I've already asked the mods to move this to the Mac forum, but just as an FYI for the future, the Mac Forum is here.
maxim_k
AutoCAD 2013 for Mac is not compatible with El Capitan and the issue with Page Setup dialog is only one of many other issues that could appear when using 2013 version on El Capitan. And there is no workaround / solution except updating AutoCAD to the latest version or downgrading OS X to previous version.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Disappointing to hear, but thanks
Sent from my iPhone
