334 Vistas, 3 Respuestas
annotative export problem
In layout i add my annotative dimension. then when i export has a pdf. it show me my drawings without any measurement.
could help me to fix it.
it is very annonying, i went online read tons of blog and nothing works.
thank you.
gaelle
maxim_k
en respuesta a: Anonymous
Can you attach your drawing for investigation?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
hello,
my problem is:
i created a layout, when i move in my viewport any 3d model, when i export , the 3d model appears on the page pdf exactly as it was: perfect.
then on the same layout page, if i put the cub view on top view, then move in the viewport my 2d drawing with the measurement, when i do exactly the same ( export to pdf) i have a blank page.
so my question is, why ? 2d drawings disappear in export to pdf, when 3d do not.
i tried to create anothe layout... exactly the same, 2d: disappear, 3d do not.
could you help me please?
thank you
gaelle
maxim_k
I cannot reproduce the problem on my side following your directions.
Look at the attached PDF I created with 3D and 2D viewports.
So, please, attach your drawing to the post here, I'll look at it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
