maxim_k
en respuesta a: ange
Welcome to Autodesk Forums!
If you setup A0 paper size for the layout, the size of the sheet should be 841x1189 AutoCAD units. So when you create viewport with dimensions 800 x1100 units and set scale 1:1 for this viewport, it will show Model space area with dimensions 800x1100 units.
Each unit in your drawing equals 1 meter, so the area you will see inside viewport will be 800x1100 metres assuming 1:1 scale.
The size of the site in your drawing is 350x350 metres, so it will be inside 800x1100 metres viewport area.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
