maxim_k
en respuesta a: Anonymous
@Anonymous wrote:
The right-click customization to repeat and enter command don't work like in older versions. If I enable it, only works if there is no object selected.
If you want to use right-click as Enter all the time, even when objects are selected as it was in AutoCAD r.14, than you need to set SHORTCUTMENU=0
If you also want to use shortcut menu (after some delay), you need to set SHORTCUTMENU=16
Please look at this Help topic:
http://help.autodesk.com/view/ACDMAC/2016/ENU/index.html?guid=GUID-27079CDD-85E0-4883-A961-82C8FC5C7F46
@Anonymous wrote:
And the delay in the cursor stops to happen when I turn ON the polar tracking,
I cannot reproduce this issue on my side.
@Anonymous wrote:
Edit: I forgot to mention that if I move the cursor too fast, the selection tool turns in to a big arrow. Very weird.
If you don't need "Shake to Find Cursor" feature, you can disable it:
  1. Go to the Apple menu and choose “System Preferences”
  2. Select “Accessibility” and go to “Display”
  3. Uncheck the box next to “Shake mouse pointer to locate”
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
