- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Welcome to the Autodesk Forums!
1/ You are trying to use wrong tools (commands) for measuring area. In your video you use button to measure ANGLE at first (which allows to measure angles between existing objects) and than you are trying to use Quick Dimension command (which allows you to quickly put dimensions of existing objects). But you need to use AREA command or Area option inside MEASURE
2/ AutoCAD interacts with user (in particular case, it should give information on the measured area) via Command window or via Dynamic input prompt. Both are closed (disabled) in your case. To turn on Command window you can use Command+3 shortcut (or menu Window -> Command Line). Tu turn on Dynamic input you can use Dynamic input button on the Status Bar or use Shift+Command+D shortcut.
Maxim
Maxim Kanaev
Architect
MARSS
