maxim_k
en respuesta a: Anonymous
Welcome to the Autodesk Forums!
When you add hatch pattern by selecting "Add patterns" from drop-down list in Hatch library window, AutoCAD adds an alias (symbolic link) to the hatch pattern you select. This alias is inside "/Users/YOUR_USER_NAME/Library/Application Support/Autodesk/AutoCAD 2016/R20.1/roaming/@en@/Support/" folder on your Mac, and you need to remove (delete, trash) this alias in order to remove hatch pattern from the Hatch Library window.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
