538 Vistas, 2 Respuestas
03-14-2016
09:09 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-14-2016
09:09 AM
Model Space to Paper Space Scaling
Why is it if you set the dimention scale to annotive in model space and draw a sceries of dimentions and then go to layout 1 and create multiple viewports each with a different scale and click on the model tab in layout 1 the dementions are reflective of the scale not the same size. If the dimensions are set to annotative and you are in layout one with model tab on and draw dimentions they all appear the same size. Does annotative scaling only work in layout 1 ect. with model tab on and not when dimensions are drawn in model space and brought over to layout 1, model space or as I think of it as paper/model space.
Greg
03-14-2016
11:35 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
03-14-2016
11:35 AM
If you dimension through viewports, that's how they appear in modelspace?
If you dimension in modelspace, they will appear any way you want in modelspace and look correct in paperspace?
03-15-2016
06:56 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
03-15-2016
06:56 AM
If I dimension with annotated objects in viewports in paperspace with different scales and go to modelspace with all annotated scale turned on I see different sizes which makes sense.
If I dimension in modelspace with annotated objects and go to paperspace and look at viewports with different scales the annotated objects are different sizes. I thought by using annotation in model space that when I went to paperspace and set viewports at different scales the annotated objects would adjust to appear the same size in all viewports.
Greg
Greg
