maxim_k
en respuesta a: Anonymous
I have no troubles with your file: "Save to PDF" and "Preview" work with the same speed (about two sec). But I don't have CTB file you are using in your page setup, I used monochrome.ctb instead.
>>>The tabloid size sheet was quick to Preview
BTW, if Preview opens quickly - I mean you pick "Preview" button in Print window - than why you don't want to save PDF from Preview application? PDF is already generated and it is exactly the same as when you use "Save to PDF".
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
