maxim_k
en respuesta a: Anonymous
This is because you have Infer Constraints enabled on the Status Bar.
You need to turn this feature off:
Plus please verify that you have no unnecessary parametric constraints in the drawing (I see you have a lot of them).
If you don't need them use "Delete constraints" from Parametric menu to delete them (use All option when AutoCAD will ask to select objects to delete constraints).
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
