1995 Vistas, 7 Respuestas
Can't seem to move ONLY ONE object
Hello, I'm new to autocad. I'm trying to follow some tutorials, but I can't seem to move things properly. If I want to move something and the object I'm selecting is touching anything else (even if that "anything" is not selected) everything gets moved. I made a video to quickly show you what I'm talking about. I also attached the file.
https://youtu.be/EgizxCKx0M4
I only want to move that green rectangle, but everything it touches moves as well.
I tried looking for posts that talk about this, but I couldn't find anything. Thanks for any help!
Etiquetas (3)
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Can you attach the drawing itself instead of the video showing the issue?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Good idea. I just attached the file to my original post.
maxim_k
This is because you have Infer Constraints enabled on the Status Bar.
You need to turn this feature off:
Plus please verify that you have no unnecessary parametric constraints in the drawing (I see you have a lot of them).
If you don't need them use "Delete constraints" from Parametric menu to delete them (use All option when AutoCAD will ask to select objects to delete constraints).
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
Here is a screenshot of Status Bar with Infer Constraints enabled:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
THANK YOU! I had no idea what that was until now.
I put the infer constraints off and it still moves more than one object :cara_asombrada: , I just switched to AutoCAD 2018, have been using 2011 for a while.
maxim_k
Hi Britney,
You also need to remove all existing constraints with DELCONSTRAINT command.
http://help.autodesk.com/view/ACDMAC/2017/ENU/?guid=GUID-E47B6F79-C7DA-45ED-AFA6-6C0945DB6375
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
