02-15-2016
08:45 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-15-2016
08:45 PM
True dimension is 412'-9" what you get from DIST command:
Distance = 412'-9", Angle in XY Plane = 0, Angle from XY Plane = 0
Delta X = 412'-9", Delta Y = 0'-0", Delta Z = 0'-0"
But the current dimension style you are using to put dimensions has 0.039370078740157 Scale Factor:
and distance in each dimension you put with this Dim Style calculated as follows: "Real Dimension" * 0.039370078740157
So you get:
412'-9" * 0.039370078740157 = 16'-3"
If you want real distance in the dim text, you need to set Scale factor in the dim style to 1.
Maxim
Maxim Kanaev
Architect
MARSS
