SharekaIqbal
528 Vistas, 3 Respuestas
SOS: 3d Fillet crashes Autocad for Mac
I am facing a major problem right now and I need help desperately as I have deadlines to complete.
The moment I try the 3D Fillet command on a set of solids, my drawing crashes. Neither can I save the drawing nor work further on it. The drawing simply will not stay open after that.
Please help.
Thank you.
stevetamplen
en respuesta a: SharekaIqbal
This is the AutoCAD for Windows forum.
You will want to post next time on the AutoCAD for MAC forum, which is located at the address below:
http://forums.autodesk.com/t5/autocad-for-mac/ct-p/3011
 I have contacted the moderator and he will move your post to the correct forum.
Steve Tamplen
Technical Support Specialist
maxim_k
Welcome to Autodesk Forums!
Have you tried to use AUDIT command in this drawing to repair errors if any?
Can you attach the problem drawing here? With directions what you want to fillet.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
SharekaIqbal
en respuesta a: maxim_k
Thanks! It worked! :cara_con_una_leve_sonrisa:
