- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Welcome to the Autodesk Forums!
Sorry, but it is naerly impossible to describe all equivalent buttons on Mac compared to Windows, because there are a lot of them. At the same time all commands and their options (if you are using them from the command line) are absolutely identical.
About your other questions:
>>>He pulled up something called design center
- there is no Design Center in AutoCAD for Mac, so uou cannot use it.
>>>> He typed on his L@12' and could choose an angle for his line, but I had to drag mine.
- in AutoCAD for Mac you enter point coordinates the same way as in AutoCAD for PC - there is no difference. For example if you start LINE command and pick first point, than you can type @12'<40 to draw line with 12' length at 40 degree.
Maxim
Maxim Kanaev
Architect
MARSS
