3392 Vistas, 7 Respuestas
CUIX FOR MAC
Hello everyone, i'm a new mac user with autocad and i can't figure out how to import a CUIX into autocad for mac ? Actually i can't find the path because it's not the same than the windows one.
If anyone know the solution it would be very helpfull.
Thanks a lot !
i just posted my actual interface
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
You cannot import CUIX file into AutoCAD for Mac, because AutoCAD for Mac doesn't use CUIX file.
It uses separate CUI files and you can customize it only via CUI command.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
thank you for the answer
HOW I CAN CHANGE THE AUTOCAD 2016 TO CLASSIC IN THE MAC.
How i can change the Autocad 2016 to Classis in the MAC.
maxim_k
Hi Patricia,
What do you mean by "classic"?
AutoCAD for Mac has its own user interface and there is only one workspace in it, which you cannot change to something other.
BTW, in 2017 version the interface was changed and now it looks more like interface in AutoCAD for PC, but still - you cannot change it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
How can I change from CUIX to CUI? I only have a CUIX file and a Mac
maxim_k
The answer is >>>>here<<<<<
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
