01-26-2016
10:52 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-26-2016
10:52 AM
Welcome to Autodesk Forums!
Hi Ashley,
Your question is quick, but the full answer is not too quick.
The quick answer is: in AutoCAD for Mac all customizations have to be done with CUI command (you can find short information about it via Help system).
With CUI command you can create new commands (macros) and assign them to the menu items and Tool Sets palette buttons which you create inside CUI editor.
You can also customize command aliases with your default text editor (use menu Customize Aliases).
You cannot customise default shortcuts inside AutoCAD as you can do on PC, but you can customize shortcuts to menu items via Mac OS System Preferences.
You cannot customize double-click actions as you can do on PC (actually you can, but only by editing CUI files directly).
You can use AutoLISP routines, but Visual LISP functions are not supported, DCL also not supported - you cannot create and use custom dialog boxes crated with DCL.
Maxim
Maxim Kanaev
Architect
MARSS
Hi Ashley,
Maxim
Maxim Kanaev
Architect
MARSS
