TravisNave
en respuesta a: Anonymous
Yes you can absolutely do this.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Window...
If you need to download the Mac version, you can do it from the virtual agent if necessary.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
Autodesk Forums:
