maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
You can use TRIM command and select vertical and horizontal lines as cutting edges, than hit Return and select arc tails.
If this doesn't help, you can try to use FILLET command with radius equal to the arc radius, than you don't need the original arc - just erase it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
