475 Vistas, 3 Respuestas
How do i adjust how the drawing appears when exported to a PDF?
Hello all. I am currently using AutoCAD to make outline drawings for PDF data sheets. However, when I export the drawings I am unable to center them on the PDF. I have adjusted several of the options including the "What to Export:" and "Page Setup:" menus, but I more or less get the same result once  the file has exported. Attached is a screen shot of the drawing with "What to Export:" and "Page Setup:" settings I use and the resulting PDF. Thank you in anticipation.
