- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi there,
This is a small thing but the little things tend to get you heh..
You know how AutoCAD often remembers/goes off your last command or setting..
Is there a way to set up the justification in Multiline Text to default to a specific setting, e.g. if you always want it to come up as ML - middle left, can I set it to do that every time?
At the moment, it defaults to TL - top left. And every time I type something I then have to reposition it afterwards. And every time I reposition it afterwards, its a little bit (or a lot) different to how I adjusted the one before so my alignment is tedious to get right. Too much mucking around - which leads me to think I’m probably doing it wrong.
The same sort of thing happens in single line - the actual letters appear higher than where i intend. I put the cursor where I want within the spot I want the letter to sit, and when I type, they’re too high.
Does anyone know about this? If so I’d really love to know please !!
Thanks ![]()
SCRATCH THIS BLEOW; you just double click on it. Off with my head, on with a pumpkin. as my Nan would say
PS. Also if anyone knows the command, or path to access the paragraph editor, I seem to have lost my way with that too ..
It tells you all about it in the online manual, but no mention of how to access it, geh.
¡Resuelto! Ir a solución.
