en respuesta a:
05:59 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-11-2016
05:59 PM
EDIT: I have since discovered one step towards my issue; the 'input text manually' box that is now ticked [dimension style, modify, fit tab, fine tuning section, place text manually tick box]. This has helped some. It still doesnt allow you to edit/adjust the existing number, you have to type both lines in, and unfortunately when you do that they no longer line up as neatly so you can tell that its been input manually which to me infers you had to override the info whcih probably means your dimensions are out... - even though they're not. Argh. Fingers crossed there is an answer out there...? THANKS !
