- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi Maxim,
Thank you for taking the time to respond !
Maybe I need to explain myself a bit better.. The problem I am having is not a case of needing to indicate a "+" (or "-"). The problem is this:
AutoCAD is automatically subtracting the lower limit value I input into the:
Dimension style manager, modify, tolerances, method, limits, prescision 0.000, Upper value 0.0230, Lower value 0.012.
I have attached a screen shot to hopefully explain it a bit better.
My goal is being able to end up with this result:
Upper limit diameter: 16.023
Lower limit diameter: 16.012 [THIS IS WHERE AutoCAD DISPLAYS THE INCORRECT VALUE of 15.88. AutoCAD has automatically assumed the Lower limit is a "-" value, I want in this case for Lower limit to also be "+" as well as the Upper limit ]
I tried your suggestion and yes I can apply a "-" or "+" in front of either the top or bottom (one or the other, not both..) but AutoCAD wont allow me to edit the numerical value itself unfortunately. This is why I am stuck becuase I cant find a way to display the correct actual number.
The edits I CAN achieve is placing a number or letter or symbol etc IN FRONT, OR AFTER the dimension displayed (either the top or bottom, not both the top and bottom), but I can not edit/change (i.e. fix) the number itself. If its says 15.988, thats it, I can not change it manually to the number I want (which is 16.012).
On the other hand I also have other dimensions that require both the upper and lower limits to BOTH be MINUS the tolerance values, so I will have the same issue in that case too ![]()
I hope there is a way!?? Thank you again for your time - once again !!! ![]()
Thanks !!!
