- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi there,
I am trying to apply limit tolerances on my drawing. For some of the components I want to show dimensions for I want both the upper and lower limit to add (be positive values) to the dimension. I cant get AutoCAD to make both the upper and lower positive.. It wants the lower to be negative.
Eg,
Diameter is 16 (basic diameter)
I want to show the following:
upper: + 0.023
lower: + 0.012
The result I'm trying to achieve is;
(Diameter symbol) 16.023
(Diameter symbol) 16.012
This will be used for holes and shafts etc. The above example is for a "n6" Heavy Push Fit (for a brass bush).
Likewise, some other components require two negative numbers so its the same problem again just the other way around. I have tried trying to edit the dimensions once they're there but it wont allow it.
Also - regarding the diameter symbol... AutoCAD thinks that the edge of my round Bush (i.e. a striaght line) is a straight line. Is there any way of getting the diameter symbol in there too even though I'm not dimensioning an actual circle?
Maybe its a case of entering it manually and trying to establish a little system myself to try and make it look consistent.. yelp![]()
Thanks !!!
¡Resuelto! Ir a solución.
