878 Vistas, 17 Respuestas
Characters missing when typing fast in MTEXT
I have a problem where when I am annotating drawings in MTEXT where character do not register as I type them. This seems to be most commonly, but not exclusively, after a space (i.e first letter of a new word) and is especially the case when I am typing quickly. This problem does not present in any other program or even in the command line within AutoCAD. Only in MTEXT.
As an example, a note such as ...
"Hardwood decking over supporting structure to match chalets. Structure to Eng's detail."
Will type as ...
"Hardwood ecking ver supporting tructure o match halets. Structure o Eng's etial." (This was typed in MTEXT as an example).
It is very annoying. I am using AutoCAD for Mac 2015 and have reinstalled it twice to no avail.
Appreciate any suggestions.
maxim_k
en respuesta a: Anonymous
I cannot reproduce the issue on my side.
Does this happens with all fonts (text styles with different fonts) from your system?
Do you have some third parity keyboard manager installed on your Mac?
What if you will type the text in some other application (text editor) than copy it to clipboard and use "Paste" from context menu in MTEXT command?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
wei503
Thanks for reporting the issue. I am able to reproduce it. It seems that inputting a space takes a little longer than other characters, and it eats the next input if typing very fast. I have logged the issue to the product development team. We will try to have it fixed in future update.
Wei
Wei Ma
AutoCAD QA Manager
en respuesta a: maxim_k
Hi Maxim_k,
It would seem so. I have just spent some time experimenting with different text styles and it presents in all cases.
No I don't.
I could do this however it would be extremely inefficent. As it stands I simply type slowly and this gives the software time to register all the characters, however this too is cumbersome. It appears that the computer doesnt have enough resources to compute the typing which is bizare given that it is a top spec 2013 retina MBP.
en respuesta a: wei503
Wei
Thanks Wei, Is there some system for notifying us if/when it is included?
Any fix to this issue yet?
tim
One year, one major update and a half dozen minor updates later, it is still a problem as of 1/27/2017. Come on, AutoDesk.
pendean
en respuesta a: tim
I'm experiencing this same issue and it's killing productivity at work, where I'm using an up to date version of AutoCAD T 2017. Please help!
pendean
Did you try the posts tips and links yet?
tim
en respuesta a: pendean
What tips would those be? All I see in that link is a mention of a hotfix update coming out that seemed to solve the problem for the original poster.
It does not, however, solve the problem for an additional poster or for a lot of the rest of us. I have logged this same problem myself with Support quite some time ago, with the end result that Support was also able to recreate the problem and that they were submitting it to Development for correction, thus allowing the support file to be closed. This was way back in the first part of the year, probably January, since that is when I made the post above.
There have been several updates since then, none of which has had any affect on the issue. I am fully up to date, with the latest version of AutoCAD LT for Mac. We are approaching TWO YEARS on this issue.
So when can we expect this (or any of the other issues I have raised with Support that have supposedly been forwarded to Development) to finally be addressed?
The several support people I have dealt with have all seemed very good. They ask pertinent questions, they request pertinent information and example files so that I feel like they are really understanding the problems I present to them. Sometimes, they are able to provide work-arounds or other suggestions to minimize the impact of whatever problem has come up.
When they fully understand the issues, they then submit the information to the Black Hole of the Development team, close the Support file, and the issue goes....  nowhere. What gives in Development? There have been Hatch problems that have existed unchanged for the full 20 years I've been using the software professionally, that have never been addressed. I had work-arounds, but got fed up and submitted my own support request on those 8 months ago. I submitted my support request on this above problem of dropping characters following spaces 9 months ago. I have submitted support requests on things so simple as a list box being loaded with layer names UN-sorted and WITHOUT the current layer pre-selected more than a year ago. That's something any computer science student learns to do not just in the first semester, but probably the first week of class. What could be more simple to fix? Yet more than a year later, there has been nothing done on that. So again, what gives in Development???
And for the specific problem at hand, the dropping of characters, what tips did you have in mind? Rereading the entire thread that you linked to, the only advice I found was to make sure your system is fully updated, which is an obvious first step to most of us. Did I miss something there? If you've got something more helpful than that, how about a more specific link to that?
en respuesta a: tim
@Anonymous wrote:
"it does not, however, solve the problem for an additional poster or for a lot of the rest of us."
Thank you! This problem is a massive time sink and should be addressed.
pendean
en respuesta a: tim
Good to know you tried the hotfix and other updates tips and ideas. Now everyone reading your posts will know you've done all the suggested common fixes.
>>>... 8 months ago...9 months ago...<<<
As a general rule, if nothing improves within 3-6 month or next version you need to resubmit.
>>>>..what gives in Development?...<<<
Don't know, we are all end users just like you.
>>>...problem at hand, the dropping of characters...<<<
How do we replicate your issue? Post a video showing the problem in action please. Since typing and wordy-posts haven't gone anywhere it night be time to rethink the how to resubmit the problem. What do you think?
maxim_k
One of the ways to communicate with developers is to join Beta testing:
https://forums.autodesk.com/t5/autocad-for-mac-forum/want-to-view-the-pre-release-version-of-autocad...
You may submit bug report and discuss the problem directly with the developer team.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
tim
3-6 months and an update or two I can live with. 12 months and 20 months and multiple version cycles not so much.
How do you replicate the issue? Easy. See original post above.
GO TO UTOCAD.
START N MTEXT R EADER.
TYPE OMETHING UICKLY.
THAT IS RETTY UCH LL T AKES O EPLACATE HE SSUE.
Sometimes it responds better than others. Right now it is actually doing quite well and can almost keep up. Sometimes, I have to go REALLY slowly to not have it omit letters. System resources would be an obvious source for a problem like this, but I have all the same stuff open right now that I always do, so not sure why it should be doing better.
I have reopened problems in the past, and received the same result: it has already been sent to Development, so we just need to wait for an update that addresses it. You are right, of course, it is time to do so yet again.
tim
Maxim
Now that's the most useful idea I've heard on this in a long time. Thank you. I will do that.
Seychellian
en respuesta a: tim
It's pretty crazy that this is still unresolved, as something as fundamental as being able to type properly should be considered a basic standard that must be met. I am interested to know why there isn't more complaints about it to be honest. Makes me wonder if it is not a user-specific issue and whether or not there are not contributing factors to it. Either way some feedback from AutoCAD would be helpful.
wei503
en respuesta a: Seychellian
Just want to update that this issue is fixed on ACAD for Mac 2018 version.
Wei
Wei Ma
AutoCAD QA Manager
