PMiddelkoop
1677 Vistas, 2 Respuestas
Status bar small
I've the some problem with my status bar, it is half the hight it should be. Tried the reset pallets trick but this opens a new session of AutoCAD with the same proplem. I'm using AutoCADLT 2015 on a MacBook Pro (Retina, 15 inch, medio 2014). I already searched the AutoCAD for Mac Forum with no luck.
Is there any solution to this problem i've missed?
Kind regards,
Patrick Middelkoop
Etiquetas (1)
maxim_k
en respuesta a: PMiddelkoop
If "Reset Palettes" doesn't work for you, you may also try to Reset Application options, but be aware - that will reset all settings to their default values.
Before trying resetting Application options I'd suggest you to check icon sizes in AutoCAD options - if you changed them (increased their size), try at first set the default size, than reset palettes again.
Another way to try is to trash "Profile.aws" file, which is in
"/Users/YOUR_USER_NAME/Library/Application Support/Autodesk/roaming/AutoCAD LT 2015 Standalone/R20.0/enu/Support/"
folder. YOUR_USER_NAME is your short user name on Mac.You need to QUIT AutoCAD before trashing this file.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
PMiddelkoop
en respuesta a: maxim_k
Thanx Maxim,
I changed te the icon sizes in the AutoCAD preferences to big and then changed them back to normal. Now my status bar is back to it's normal size.
I hope they stay this size, but now I know, if they change again, what to do.
Thanx again.
Patrick Middelkoop
