en respuesta a: maxim_k
Umm..
So yes when the USEQUARTZFONT is set to 0 the the Plot Job processes the PDF quickly, the speed at which I've always been accustomed to with CAD.
When the USEQUARTZFONT is set to 1 fixed the the Plot Job processes the PDF slowly.  It eventually creates the PDF, but takes much longer than it always has.
I've checked multiple files and this is case with all.  There's isn't a great deal of text in the files.
I am not sure if I am using a special TFF font (am not sure sure what that is).  The files, fonts, and titleblocks I am working with are all the same that I was using prior to upgrading from 2015 LT to 2016 LT.
Should I not be PDF'ing architectural drawings with the USEQUARTZFONT setting at 0?   I am unfamiliar with this command, and to my knowledge it's always been set to a default setting.
Kenneth
