378 Vistas, 3 Respuestas
Trouble with interpolation
I have an instruction in my AutoCAD homework asking me:
"The end points of the section line and the river surface (elevations) should be interpolated and plot as well."
The green horizontal line is the section line, the blue spline is the river and the red perpendicular dash lines are the lines I need to interpolate to find how far down they should go from the section line.
The white perpendicular lines from the intersection between the contour line and section line go down to their specific CONTROL lines which are offset by 5 units apart from each other. I don't know how to figure this out it was not shown in class and I'm not the best with figuring out an interpolation equation.
en respuesta a: Anonymous
I need to figure out where the control points will land from the end points on either side of the section line and from the intersection of the river and section line down to the control reference lines
Bump
maxim_k
Seems your question is not AutoCAD related, or I cannot figure out what do you need, sorry.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
