en respuesta a: maxim_k
Maxim, Thanks for getting back to me. What I was looking for is an AutoDesk person based in the US to talk to. I think I have found that. I was interested in knowing if you had any of the answers to these three questions. I have AutoCad LT 2015 for MAC. 1. When I turn on the program I can select a number of templates. Three of them I get a full blue workable screen. The rest of them show a white template with a gray background which covers up the coordinate display. Are those templates with the gray background for AutoCad only and if they do work with LT then how do you turn off the gray background. 2. On the command line copy clip keeps showing up on the command line and I have to clear it often. What is that all about. 3. When I try to set the limits and say set them to 12,9 the upper right hand corner of the screen is much higher. On my older AutoCad LT when I set the limits to 12,9 the upper right hand corner would always read 12,9. Where are you from and are you from AutoDesk. Thanks, Greg
