385 Vistas, 1 Respuesta
11-18-2015
04:10 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-18-2015
04:10 PM
AutoCAD LT 2015 on Mac - PDF Export/Print Issues
Having issues converting a drawing to PDF. I've tried exporting to PDF, and it goes through the process but doesn't create a file. I've tried printing to PDF using the "PDF" button in the lower left of the print screen, and when set for "Layout" it creates a PDF of a small section of the drawing, not the entire layout. Both "Extents", and "Window" with the window around the exact area I want to represent creates the full drawing, but with a large blank space extending up about 1/3 of the overall page size, when no blank space is actually there on the dwg drawing.
Any help is appreciated.
11-19-2015
02:11 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
11-19-2015
02:11 AM
Welcome to Autodesk Forums!
In order to get correct results when you export (save from Print Preview, Batch publish) to PDF, you need to create named Page Setup in Page Setup Manager and set it current for the Layout or Model space you want to export to PDF.
Without doing this the results could be unpredictable.
Maxim
Maxim Kanaev
Architect
MARSS
Maxim
Maxim Kanaev
Architect
MARSS
