402 Vistas, 1 Respuesta
License Export?
When i try to open autocad, it says that "The license for this product is currently being exported, you may not use a product whose license has been or is being exported. To use this product, import the license back to this computer when the export has completed"
TravisNave
en respuesta a: Anonymous
If you are using the License Transfer Utility, don't.
Autodesk Forums:
