en respuesta a: maxim_k
Hi Maxim,
Thank you for your guidance !!
I'm sorry but I'm still running into trouble.  I have tried the following but still have not magaed to get it working corrcetly:
You have helped so much already, and Im pretty sure going off what you have told me that its the nut behind the wheel - not a problem with AutoCAD.  I totally understand if you dont have time to help me with this any further..
If you are able to help me more (THANK YOU!!), and here is whats happening:
When I open a new drawing based on the template that contains my original working title block, (the one where i double click ion it and the advanced attribute list pops up ready to be filled in)  , I go to layout,( and paperspace), highlight the bock and type in the comman line "blockeditor", enter.
"0" is coming up saying read only.  I try not high lighting the block and still the same read only message.
So i created a new block and select exactly the original block (so when I select it it looks like one object).  I save it in my Blocks folder eg "Title Block A3.dwg".
Then I open a new drawing , create a new layout, insert the new block I've just created.  Double click on it and it goes into Block Editor mode :cara_de_decepción:
So the only block that is working correctly seems to be read only in block editor.
I did not create the working block, I just have a template that is pretty much that title block.
So I go ahead and try anyway with the new block that WILL open in block editor, use ATTDEF to add a couple of attributes, then make another block ;
w, write block etc
save that eg "Title Block 1.dwg,
Then i open a new drawing,
insert my new block Title Block 1.dwg
double click on it and:
it opens in block editor :cara_de_decepción:
so I double click on one of the attributes and it opens up each attribute individually rather than compiled into one list.
Thank you again for all your help - i understand if you have not made it this far though... but if you have THANK YOU !!!!!!!!
