1528 Vistas, 2 Respuestas
snapping problems
I am very new to AutoCad for Mac. I have 2 issues. Please help .
1. My issue is snapping in 3D. My goal was to draw a simple roof. Started with drawing a long  line and the second shorter line perpendicular/ horizontal  to the first one in the middle. I got so far a sort of the a letter "T" upside down. Then I used the PLINE to draw the polyline to create a triangle. Started at the end a long line and try to snap at the top end of the shorter/horizontal line. I can not do it. Only snaping point available is the bottom end of the horizontal line and the line does not want to be connected to anywhere else.
What am I doing wrong ?
When I use just LINE command I have no problem to draw all those regular lines and all lines snap the way I want.
2. Issue of blue snapping points. When I want to draw a polyline to connect to a 3D object I see blue color snapping points. Why blue? So far all snapping points have been green. Where to find more about that issue ?
Thank you
Kris
