473 Vistas, 5 Respuestas
Dynamic Blocks - text attribute justification
I am having issues with a simple dynamic block.  I created a block with a stretchable box with a text attribute in the center, the text justification is set to middle-center and the insertion point is in the center of the box.  Everything looks great in the block editor; however, as soon as I close out the text shifts to the left and the alignment is off center.
Etiquetas (1)
maxim_k
en respuesta a: Anonymous
Have you tried to lock attribute position in block editor using Properties palette and then reinsert the bock in the drawing?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Yes, at the moment the text is locked.
maxim_k
Sorry, but now I cannot look at your drawing, will do later.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
dmcclure
Did anyone ever find an answer to this problem? It's driving me nuts with my titleblocks.
john.vellek
Hi @Anonymous,
I can't duplicate the problem (at least on Windows). I see that you are using a textstyle with AvantGarde as the font. Does the problem still show up if you are using an AutoCAD font such as romans?
I will try this on a Mac as well to see if I can duplicate the problem there. - UPDATE, I am unable to duplicate this on the Mac either.
Please update your post.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
