en respuesta a: Anonymous
@Anonymous wrote:
Hi!
I'm a user of Autocad 2015 on a iMac 2,9 GHz and of Autocad 2013 on a Mac book pro 15'' late 2009.
I've recently ''upgraded'' both machines to OSX EL Capitan. Whenever I'm trying to access layer manager the program just crashes. That also happens even when I put the cersor on the new layer icon. As you can understand it's almost impossible to use the software for any architectural drawing. After several tries, I've reinstalled Autocad 2015 and I've tried also with Autocad 2013 and 14 but the issue remained.
I'm studying in one of the most demanding universities of the world and the deadlines are coming the one after the other. I've been using Autocad for 6 years and Mac for the same period and I have never faced such a problem. I've noticed that Autodesk is working on a fixing for the El Capitan. Do you think that my problem would be solved too? Or do I have to downgrade to Yosemite (which is a painfull procedure) ?
Thank you
AL
Read this thoroughly: http://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticles/Mac-OS-X-v10-11-x-El-Capitan-compatibility-with-AutoCAD-for-Mac-and-AutoCAD-LT-for-Mac.html
