836 Vistas, 4 Respuestas
Crashes when editing text fields!
Need help finding a solution that keeps crashing the program when editing text, cannot find the answer, anyone have an idea?
Just upgraded to the OSX 10.11 (El Capitian)
Using Autocad LT for Mac 2013
Issues appeared after OS upgrade.
Process: AutoCAD LT 2013 [866]
Path: /Applications/Autodesk/*/AutoCAD LT 2013.app/Contents/MacOS/AutoCAD LT 2013
Identifier: com.autodesk.AutoCAD_LT_2013
Version: 19.0.55.305 (19.0.55.305)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: AutoCAD LT 2013 [866]
User ID: 501
Date/Time: 2015-10-02 16:08:43.865 -0400
OS Version: Mac OS X 10.11 (15A284)
Report Version: 11
Anonymous UUID: C38DBCD4-3375-32E6-26EB-CBD68C54CB4E
Time Awake Since Boot: 2800 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGILL)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000111350ef0
Exception Note: EXC_CORPSE_NOTIFY
VM Regions Near 0x111350ef0:
shared memory 0000000111304000-000000011134d000 [ 292K] r--/r-- SM=SHM
--> shared memory 000000011134d000-0000000111351000 [ 16K] r--/rw- SM=SHM
MALLOC_LARGE 0000000111351000-0000000111371000 [ 128K] rw-/rwx SM=COW
Global Trace Buffer (reverse chronological seconds):
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
The only one solution at the moment is to roll back to Yosemite.
Further more I'm afraid the Update for AutoCAD 2013 will not be released, but
I'm not absolutely sure.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
Another way is to try this:
http://forums.autodesk.com/t5/autocad-for-mac-general/autocad-for-mac-public-beta-available/td-p/579...
Beta works on El Capitan.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Thank you Maxim, the beta is the solution for now I guess.
*Tom Weintz*
President
ISA Certified Arborist FL-5436A
Commercial Applicator (FDACS) CM17289
I am having the exact same problem! Any help would be greatly appreciated. Not sure I want to go through the steps to revert back to Yosemite but may have to as I cannot finish a single drawing without a crash. Very frustrating!
