07-17-2015
09:37 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-17-2015
09:37 AM
Welcome to Autodesk Forums!
I think the point is that you are using "Last Using Settings" in Presets drop-down list below the Printer drop-down in Print window.
In order to change the behavior you need to change Presets settings to "Default settings" and pick on Print button - you will get settings you adjusted just before you pick Preview button. Now if you will pick on Print button the Presets option for the printer will be changed to "Default settings" when you will open Print dialog next time.
And with "Default settings" option changes you will make in Print dialog will not reset after you pick "Preview" button.
I also advice you to use Named Page Setups in the printing process - you can create them in Page Setup Manager and than use in Print window.
Maxim
Maxim Kanaev
Architect
MARSS
Maxim
Maxim Kanaev
Architect
MARSS
