wispoxy
en respuesta a: nh0c.nicolas94
That command hasn't been implemented yet, which I didn't know. You can use the command, but it uses a different command tool, which takes you through a long annoying process.
Look into these three:
## 1 ##
Reference Manager, AutoCAD has a separate program to edit and update all references quickly.
Start -> All Programs -> Autodesk -> AutoCAD 2015 -> Reference Manager
## 2 ##
Command FIELDEVAL
Look at the fieldeval variable.
  1. At the Command prompt, enter fieldeval.
  2. Enter a bitcode that is the sum of any of the following values:
    • 0: Not updated
    • 1: Updated on open
    • 2:Updated on save
    • 4:Updated on plot
    • 8:Updated on use of ETRANSMIT
    • 16: Updated on regeneration
    For example, to update fields only when the file is opened, saved, or plotted, enter 7.
## 3 ##
Command UPDATEFIELD
