306 Vistas, 1 Respuesta
Mac only plotting half the page
Last week, The bond in our plotter at work was switched to 24" from our normal 36". Since then autoCAD has only been plotting half of the page when i try to plot.
Here is where it gets tricky.
-What is printing is NOT running of the page, it stopping halfway across the sheet in a proportion that would make sense to what I am printing.
-In Page setup manager I have switched from ARCH D Landscape to ARCH D portrait.
-I have gone through my print settings and everything appears to be correct, I have printed in this format before manytimes, this seems to be an isolated incident.
-It is also doing this when I try to print PDF's at this size
Does anyone have any thoughts?
Is there any useful information I may have left out?
Thank you.
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
HI,
I think you need to find a way to correct plot settings inside your plotter software, I mean you need to change paper properties in the plotter dependent section of Print dialog.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
